hello experts i have issue with importing audio in xpression. here is the image of error. what does this mean ?
I'm having the same issue as well. I'm trying to set up audio with the Xpression system, we haven't been using it and would like to.
Hey Sunil,
Can you send me a copy of this audio file? I will test it here.
bderry@rossvideo.com
Can you ensure that the audio file is Linear PCM at 16 bits.
Let me know when you get a chance!
Yep, that was my issue. When outputting audio via Xpression without using AES audio, just using two channels, which audio output from Xpression should be hooked up?
here is the audio iam facing error while importing.https://drive.google.com/open?id=1j17FbcMgFeKuBKdwRUbnY_MCx1GYtpjd
now its working , i just again convert to wave in 48ghz then its working now . thank you
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
