Thanks guys,
Yes, this is definitely the ideal use case for dashboard, but i so much as I have 0 experience with it, I am hesitant to open up that can of worms, when this is but one part of a package which needs to be wrapped one week from today,
Since I don't know how to script this kind of thing, I have started setting up a fairly complex VL rig to do the do.
Basically it starts with the 16 names. I have published radio buttons with a 0, 1, or 2 option for each match, with 0 being no winner (yet), 1 indicating the person in the upper position of the plate wins, 2 indicating the person on bottom wins. That drives the text in the next set of of match-ups to display the winner's name in the next stage of the winner bracket and the loser's name displays in the correct position of the loser's bracket
So, then I need some manner of animation on the match-up plate to denote a match has ended and contestants are advancing, So I have this bright set of 4 chevrons move through the panels. This animation is on all the plates, but I have a second set of radio buttons which drives the visibility, so that when the operator has the results of the first match in the Winners Top16, they'll first click 1 or 2 from above to select the winner, then click on 1 in the Top 16 advance, and take the scene. The winner's name will go from white to yellow, their name will appear in the top line of the Winner's Top 8 match 1 plate, the loser's name will appear in the top line of the Loser's Round 1 match 1 plate, and the chevron animation will play in the full plate for the Winner's top 16 match 1, and then only in the top halves of the winners top 8 match 1 and loser's round 1 match 1 plates.
It's a rather intense setup, and so far seems to be working, but the operator will need to make sure that the status of 3 buttons are set correctly before taking the scene.
