Here is a code that I have started for the above. Hoping someone may be able to help and see if I am close. I know little about scripting, so any help is appreciated. Once I get this first one down I think I should be okay.
dim vistimer as xpTextObject
dim hometimer as xpTextObject
dim oddmantimer as xpTextObject
dim vis as string
dim home as string
dim odd as string
dim x as integer
dim SceneDirectorHomeIn as xpSceneDirector
dim SceneDirectorHomeOut as xpSceneDirector
dim SceneDirectorVisIn as xpSceneDirector
dim SceneDirectorVisOut as xpSceneDirector
dim SceneDirectorOddIn as xpSceneDirector
dim SceneDirectorOddOut as xpSceneDirector
self.getSceneDirectorByName("HomePenaltyIn", SceneDirectorHomeIn)
self.getSceneDirectorByName("HomePenaltyOut", SceneDirectorHomeOut)
self.getSceneDirectorByName("VisitorPenaltyIn", SceneDirectorVisIn)
self.getSceneDirectorByName("VisitorPenaltyOut", SceneDirectorVisOut)
self.getSceneDirectorByName("SpecialPenaltyIn", SceneDirectorOddIn)
self.getSceneDirectorByName("SpecialPenaltyOut", SceneDirectorOddOut)
self.getobjectbyname("vistext2", vistimer)
self.getobjectbyname("HomeTime", hometimer)
self.getobjectbyname("OddManTime", oddmantimer)
vis = vistimer.text
home = hometimer.text
odd = oddmantimer.text
if home = "x" and vis = "" then
SceneDirectorVisIn.PlayRange(0, SceneDirectorVisIn.Duration)
SceneDirectorHomeOut.PlayRange(0, SceneDirectorHomeOut.Duration)
SceneDirectorOddOut.PlayRange(0, SceneDirectorOddOut.Duration)
end if
