Thanks for the response Gamer.. I'm using 3.20 build 1767. It seems I wasn't entering a start frame so by default it was capturing frame zero, which is nothing.. you'd think it should default at frame 1 or the last frame? Also, when I export this way, when i'm ready and hit export.. it never says it's finished.. i have to cancel then go to where I put the grab and see if it worked.. sometime's a file there and sometimes not.. certain projects I need stills of all the graphics I build and when I have a hundred graphics it would take forever to do it this way.. i wonder if there is a way to automate it..
Gerard.. thanks for your response.. when i set a movie file to autostart off and drag the material on a track in the scene director.. i'm able to 'scrub' through the movie file and find a point I want to grab, once I find that point how do you export? since I didn't call the graphic to an output channel via the sequencer, when I go to sequencer there is no take item to right click onto that's on my output.. can i grab a still from the design mode (f3)? Also, when dragging a scene to the avi output, i don't get a onscreen progress window.. the only way I can tell xpressions is doing something is by looking at the performance bar.. which is well over 200%
Any way to export as a quicktime movie..
thanks guys for your input..
