can you share the file one more time
Bam Bahadur Thapa
Freelancer Graphics Designer
Freelancer
Kathmandu Nepal
Sent: 01-17-2024 11:30
Subject: Ross Xpression Lines
Here you go!
https://transfer.rossvideo.com/f/8c1c30c9d8fac047
Brandon Derry
Sent: 01-16-2024 18:18
Can you post this again? I'm trying to do the same thing and can't find a script to do it.
SS Blank
KSL TV5
Sent: 06-24-2019 05:13
Sunil,
Here is a basic project that should help with this, I have 3 textobjects that represent X,Y,Z.
Each textobject has a "OnSetText" Script that runs when the text is changed, this script will set new position coordinates for the second point in the first point list.
Here is the project: https://transfer.rossvideo.com/f/d65068d41d08fc05
