  • 1.  Automate Video Coder
    Posted 07-17-2019 15:40
    We often use the XPression Video Coder to transcode custom graphics made in the newsroom to the XPression video codec for use in templates.
    Right now all of those graphics have to go through production before they can be used. Once they get to us they each follow the exact same process, sharing the same import and export locations, so we're just kind of a speed bump in the whole operation.
    Are there any command line options for the XPression video coder? Or any other way anyone has come up with to automate this process?
  • 2.  RE: Automate Video Coder
    Posted 07-18-2019 17:51
    Ross sells a system that has the ability to do this, Ross XPression Incoder. You basically set up watchfolders that you drop content to to be transcoded to the XPression codec and it'll output it directly to your XPression clip store. I do believe there is also a setup you can do in After Effects and Adobe Media Encoder to encode in the XPression codec natively from your projects so that you don't have to worry about using Video Coder. There used to be a tutorial video on how to do this, but I'm not sure if it's still out there.
  • 3.  RE: Automate Video Coder
    Posted 07-29-2019 03:15
    Video coder does accept some command line parameters:
    /listcodecs  - which will show a dialog box listing all available codec names
    /writecodecs - will write a list with available codec names to codecs.txt located in the current folder
    source=[filename]
    target=[filename]
    codec=[codecname]
    targetframerate=[framerate]
    e.g. videocoder.exe source=test.mov target=test.avi targetframerate=29.97
  • 4.  RE: Automate Video Coder
    Posted 07-30-2019 15:43
    Wow, thanks Brian! That's exactly what I needed. It's odd that they never bothered to write a /help command.
    For anyone else who's looking to do this, below is the script I'm using. I just leave it running on the computer with Video Coder installed. Set [WATCH FOLDER DIRECTORY], [FRAME RATE], and [POLLING DELAY] to suit.
    @echo off
    SET dirWatchFolder=[WATCH FOLDER DIRECTORY]
    if not exist "%dirWatchFolder%" md "%dirWatchFolder%"
    cd /D %dirWatchFolder%
    echo XPression Video Coder Utility
    echo Monitoring %CD%...
    :loop
    for %%a in (*.mp4 *.mpg *.mpeg *.avi *.mov *.mxf) do (
    for %%b in (.\Completed .\Processing .\Failed .\Old) do (
    if not exist %%b md %%b
    move /Y ".\%%a" ".\Old\%%~nxa" >nul
    echo Encoding %%~nxa...
    pushd "%ProgramFiles(x86)%\XPressionStudio"
    VideoCoder.exe source="%dirWatchFolder%\Old\%%~nxa" target="%dirWatchFolder%\Processing\%%~na.avi" codec="XPression Video Codec 5.7" targetframerate=[FRAME RATE]
    popd
    if exist ".\Processing\%%~na.avi" (
    move /Y ".\Processing\%%~na.avi" ".\Completed\%%~na.avi" >nul
    echo Completed.
    ) else (
    move /Y ".\Old\%%~nxa" ".\Failed\%%~nxa" >nul
    echo Failed.
    echo Monitoring...
    ping -n [POLLING DELAY (IN SECONDS)] localhost >nul
    goto :loop
