What kind of scoreboard controller will you be using to provide the data? There's a setting in the Daktronics Allsport 5000, for instance, that will actually do this for you. It's certainly not a clean, animated "slide", per say, but it's certainly a simpler method of only showing 9 or 10 innings at any given point, regardless of how many have actually been played.
