Can you control the playout of clips dropped into a scene from Clip Store through Visual Logic? We’re working on a scene that will allow producers to add font to a pre-rendered background animation. The animations will need to be loaded into Clip Store in order to prevent adding new materials to the project each time, as well as to help manage these clips among our station group. Animations are dropped into a background element in the scene. I’m trying to use Visual Logic to pause & play the face material in background based on the keyframe position on a scene director. See attached image.
If the material is built into the project, this works. Currently clips loaded from the clip store automatically play. I’ve tried using scripts in the scene director as well, but it does not pause the clip store clips. Is it even possible to do this? Thank you.
