  • 1.  Bounding box height not 0?
    Posted 03-22-2019 16:53
    Hopefully this is an easy one. I have a set of bulletpoints with a background box. The height of the box is driven through Visual Logic by the sum of the texts' bounding box heights, plus a line gap. Everything works great until I remove all the text from a line or two. The bounding box height of the empty line(s) does not equal 0. Seems to default to 33. So even though I only have two lines on screen, the box is way too tall. I'm sure I can work around it by plunking some isEmpty blocks in there, but I kinda want to know what's happening for future use. Is an empty text field never 0? Do I need to feed it text from a different text block to make it truly 0 when empty?
  • 2.  RE: Bounding box height not 0?
    Posted 03-25-2019 11:45
    The bounding box still has a height when there are no characters. I would use length block or IsEmpty block like you suggested.
