  • 1.  Right Justified auto size of BG to match text size
    Posted 09-30-2019 20:15
    I have a lower third bg that slides in from screen right. It includes a mask that wipes on sponsor logos that are pre-positioned and do not move. Two line name supers animate on using stagger animation. I need to auto size or position the BG to make room for longer names. If the supers came from the left it would be a piece of cake. But I can't figure out how to decrease the x position of my L3 group as the size of the bounding box increases.  I don't need to resize material, I just need to adjust the x position of the bg relative to the length of the text.
  • 2.  RE: Right Justified auto size of BG to match text size
    Posted 10-02-2019 17:07
    Found a workaround. Build it like a left hand reveal with all the math/visual logic, then just do a negative scale of the bg on x which flips it around.
