Searching the forums, it looks like this doesn't work but I'm really hoping I just overlooked a solution.
Pretty basic, I want to use a quad to REVEAL another layer, like an alpha mask in After Effects. Let's say I have a 500x500 quad with a video material and I only want to see the middle 100x100 area. I can easily mask that area out with a 100x100 quad with a mask texture, but I need the opposite: the cropped 100x100 center with the outside masked away. I played around with blending options, mix values, layer objects but never got what I needed. And I need to do this multiple times in one scene so I'd like to keep it to two objects per crop if at all possible. Can this be done?
