  • 1.  Group Object Bug?
    Posted 01-25-2013 22:09
    Not sure if this is a bug or something I am doing wrong. When I put some objects into a group they will randomly jump a short distance. Each time I put them out of the group and put them back in they jump further and further from where they should be.
    http://youtu.be/n_HaT6CJCVA
  • 2.  RE: Group Object Bug?
    Posted 01-25-2013 23:06
    I am currently working with Garner on this issue.
  • 3.  RE: Group Object Bug?
    Posted 03-06-2014 19:53
    I am not sure if anyone has officially reported this as a bug or figured out a solution in the last year? I have been working around it with some difficulty, however now it has taken a great deal of time to find objects that transform into nowhere when I create a new group and move the object(s) within that new group. I first have to zero out the new group because it creates arbitrary numbers for the transformation matrix. I set position & rotation to zeros and scale to 1 before placing the child object within the parent group. I know others have experienced the same issue, not sure if anyone has a solution. It may be noteworthy that we are using XPression for Virtual Sets and Augmented Reality, so we are used to moving objects and groups from 960,540 to 0,0 when we create them. What I am describing here are arbitrary numbers that appear in the Pos, Rot & Scale values when selecting insert group. Any thoughts anyone?
  • 4.  RE: Group Object Bug?
    Posted 01-13-2016 21:16
    Put the group's values to 0.
    x=0, y=0 and z=0.
    Then insert the objects in the group.
