  • 1.  Piechart animation
    Posted 08-14-2013 17:17
    A little question to the guys of Ross: @bolson, @jmorrison, @gmaxheleau
    Any view on whether or when the Angle-feature of the cylinders might become available for keyframing?
    Because right now if you want to animate a piechart in, I can't see any way of doing it and it would be very helpful in some cases.
    Cheers,
    Kenneth
  • 2.  RE: Piechart animation
    Posted 08-19-2013 13:57
    There is no set date or release version of it yet! I will add it to our weekly development call and get back to you.
    Cheers,
    -g
  • 3.  RE: Piechart animation
    Posted 01-27-2014 16:00
    yes its, posiblem, just animate something from 0 to 1 on xpos (anim)
    (on render)
    Dim i as Integer
    Dim dato(4), anim, debug as xpTextObject
    Dim slice(4) as xpCylinderObject
    Self.GetObjectByName("debug", debug)
    Self.GetObjectByName("anim", anim)
    For i = 1 to 4
    Self.GetObjectByName("dato" & i, dato(i))
    Self.GetObjectByName("slice" & i, slice(i))
    Next i
    i = 0
    For i = 1 to 4
    slice(i).EndAngle = ((Dato(i).Text * 360) / 100) * anim.posX ((this will do the animation))
    if slice(i).EndAngle = 0 then
    slice(i).Visible = false
    else
    slice(i).Visible = true
    end if
    Next i
    i = 0
