  • 1.  Children within a Layer Object
    Posted 08-01-2019 23:57
    I have a text field with a quad child in order to auto scale the quad based on the text length.  Something I've done a million times before.  However, when I do the same thing within a layer object, the quad blocks the text field due to the layer order.  Is there a way to correct this?  Or is there some visual logic to apply the auto scale to the quad based on the string length of the text field?  I can't bring everything out of the layer object because I have a mask and scripted positioning within the hierarchy.  Any ideas?
    Thanks.
  • 2.  RE: Children within a Layer Object
    Posted 08-02-2019 06:04
    1. Set LayerObject at Rendering tab, Depth Sorting on Automatic.
    2. Set Text object at Rendering, Render Order Priority to Normal.
  • 3.  RE: Children within a Layer Object
    Posted 08-02-2019 12:06
    Thank you!  I had the Layer Object depth sorting set to Manual.
