Hi. I wish to share a project with animated data driven line charts. It can have some errors but is usable. Feel free to use it as you want.
https://github.com/nicolasjuan/xpLineChart
Thank you!
We should create a warehouse.
Yes! it would be helpful. There isn't lot script resources, it is hard when you have to code something.
Thanks! this is very helpful!. But, is there a way to make the the lowest number in the highest spot?
I think there would be no problem... but what is the case? what you trying to do?
for example i have data like this: 0,1,3,2the way your line chart working will be placing 0 in the lowest spot, and 3 in the highest spotis there a way to make 0 in the highest spot, vice versa
I think i understand:
Is it what you need?
I leave you the project modified for this use plus other options of graphics (bars, evolution of days, ...)
https://drive.google.com/file/d/1gLmvS_oA4ZsIl8i7QTTVlfFiPrKW7y9V/view?usp=sharing
Let me know if you have any problems or need another thing
yes, thank you so much, this will doi will check it right away, i'll let you know if there is any problem
Hi Nicolásit's actually worked! Thank you so much for that.But, sometimes when i try to put it online, my Xpression is always crash, and i can't find out why.Do you have any idea?
I found that sometimes if you have the Materials panel open when you go online the program crash, so try avoid that.I'm trying to find an alternative script so that it does not occur.
ah okay, will try that tomorrowThank you!
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
