  • 1.  XPression Audio Exported with Video
    Posted 01-05-2015 21:29
    Has there been a change made in the way XPression handles audio? I recently rendered video out of After Effects using the XPression Codec, and inadvertently exported audio. When I got it into XPression and replaced the video on an existing scene, my audio started to echo. Removing the audio track solved the problem, but I was under the impression that the audio could not be "embedded" with the video track, and that the audio had to be laid down separately within XPression.
    Did I miss this change somewhere?
    Running Xpression v5.5 build 2722
  • 2.  RE: XPression Audio Exported with Video
    Posted 01-05-2015 21:33
    XPression has always had the ability to have the audio embedded in the video..
    There are several reasons why people prefer to lay down a WAV file instead though:
    1) to have music trail off for several minutes after the video clip ends without needing to render a 5 minute long video..
    2) you can't adjust the audio levels of the embedded audio like you could with a WAV file.
  • 3.  RE: XPression Audio Exported with Video
    Posted 01-05-2015 23:54
    Thank you, Brian :)
