  • 1.  Stagger Animation from Right to Left
    Posted 05-11-2016 04:40
    Is there a way to make a Stagger Animation run text from Right to Left, instead of Left to Right? I've got a graphic screen right and I need the text to animate on from the right, but I can't figure out how to reverse a Stagger Animation.
  • 2.  RE: Stagger Animation from Right to Left
    Posted 05-11-2016 16:44
    Try putting a minus in the Timing Offsets in the Stagger Animation and then reverse the stagger animation in the scene director (right click "Reverse Direction") on the specific text object in question. Hope this helps. Please see attached...
    Regards
    Joph
  • 3.  RE: Stagger Animation from Right to Left
    Posted 05-13-2016 02:51
    Perfect, thank you! I didn't even know that Reverse Direction was there! I had to change the timing a little on the offset, but it works like a charm. Thanks!
