v8.5 build 4567
Input 59.94i via Graphite. Video formats from switcher / Xpression match.
Using the Record Client.
I was wrong when I said JPG, I was grabbing PNG. I just tried TGA and got same result.
It looks like it's recording an alpha channel in the grab and that's causing the problem. The only place the grab looks correct is the thumbnail within Record Client. Once "Sent to Clipstore" it comes out with all dark areas looking white, and I see an alpha channel associated to it in the Clip Browser.
