  • 1.  Invert Waveform Continuous Animation
    Posted 09-18-2012 01:19
    Is there a way to invert the waveform in continuous animation? I need the pause to be on the low side of the of the waveform instead of the high.
  • 2.  RE: Invert Waveform Continuous Animation
    Posted 09-18-2012 18:10
    Try moving the Phase Offset in the negative digits, see if that does it for you.
    Neil Hopley
    Wireframe Group
    www.groupewireframe.com
    514-261-4380
