Thanks. I have it working now.... although, it isn't quite working correctly. I have my hidden Datalinq Key visible and I can see that it does change when I change the parameter in Dashboard.... however, the name that I have linked to the Datalinq Key seems to only update every other time.
So if I change the parameter in Dashboard and take the scene, it is still the old name (though I can see the parameter number has changed). If I take it offline and then on again, only then will the name have updated too.
If I try to change it live, I can see that the hidden Datalinq Key number changes as I change it in Dashboard, but the name only changes every second time... and to the previous name that it didn't load when the change was made.
Jake Lew
Access Communications Co-Operative Limited
Sent: 08-16-2022 15:40
Subject: Datalinq Key Value driven by a text object
Right-click in the field and choose a text object.
Or you can just write @textobjectname@
Just put the text object name between "@"
Sent: 08-16-2022 15:37
To bump this.... I've got Xpression 10, I don't see this feature. Nor can I seem to figure out how to do it with scripting, which I am hoping to avoid anyways if this feature was actually added. Where can it be found?
Jake Lew
Sent: 01-11-2019 22:32
The next next release of XPression, probably version 9, and probably sometime between April-August, will allow this to be done without scripting.
