  • 1.  Channel 2 Preview, VL and Data Increment
    Posted 11-23-2014 22:17
    Hello, I build a simple code in Visual Logic to compare datafields in an excel document. It checks the rows and shows or hides visibility of a 3 line, 2 line, and 1 line, based on the information in the columns. I have a couple hundred pages, so I used database with increment. I have a good preview in the Sequencer Preview, but when I check my second channel being used as a preview monitor, it only shows the static template data.
    Any Ideas?
  • 2.  RE: Channel 2 Preview, VL and Data Increment
    Posted 11-24-2014 22:28
    great question.. anyone??
  • 3.  RE: Channel 2 Preview, VL and Data Increment
    Posted 11-25-2014 18:52
    What version and build of XPression are you running?
    Can you send us a screen capture of your 'Preview & Monitor' tab from the XPression hardware setup?
