  • 1.  XPression RenderView
    Posted 05-25-2013 00:41
    Can anyone explain how to create a RenderView of a scene, and any potential applications for doing this?
    There's nothing in the Help that I can find about it.
  • 2.  RE: XPression RenderView
    Posted 05-25-2013 08:31
    Hi David
    Render view is a pretty cool way to apply i.e. a roll or crawl as a material to a surface. As an example I have wrapped a credit roll around a cylinder.
    Or you may have a scene with a continuous animation on, which you want to use as surface on a 3D object.
    So here's how to create roll as a renderview material:
    - build your roll scenegroup
    - create a new material
    - add a new shader
    - select render view
    - in the dropdown list select the scenegroup
    - apply your new renderview material to your object.
    - put the scene on-air
    - done
    hope it works for you.
    Best
    Niels
  • 3.  RE: XPression RenderView
    Posted 05-25-2013 15:37
    Hi Niels Borg !
    when i put the scene on-air.first run i work good but second run it not run (i make scene group with crawl text)
    tell me how to make it work good for second and more runing
    Thank
  • 4.  RE: XPression RenderView
    Posted 07-17-2013 10:27
    Hi Hung,
    Sorry for the late reply. I have experienced the same issue and I have raised as a support case. Will keep you posted.
    Best
    Niels
  • 5.  RE: XPression RenderView
    Posted 08-21-2013 21:42
    Also trying to work with this. Not able to get it to run at all. Not using a scene group, just trying to use a scene as a Material. Does it not work with video clips?
