  • 1.  SEQUENCER PLAY RANGE
    Posted 02-27-2019 20:18
    I have a scene in my sequencer that I use for still images. The play range is selected and set to 0 to 0. But for some reason when I copy paste this scene, the pasted copy sets the play range to 0 to 100. I'm not sure why this is happening. Is there something I'm doing wrong. I want the pasted scene to be 'play range' 0 to 0; like the original scene.
  • 2.  RE: SEQUENCER PLAY RANGE
    Posted 02-27-2019 20:30
    Confirmed this is a bug. What version are you currently running? We can correct this in the 8.0 and/or 8.5 builds if you are on those
  • 3.  RE: SEQUENCER PLAY RANGE
    Posted 02-28-2019 18:55
    This should be fixed in version 8.5 build 4579 and higher. Contact tech support and ask for that version.
    Let us know if this resolves the issue.
    Thanks.
  • 4.  RE: SEQUENCER PLAY RANGE
    Posted 03-01-2019 17:48
    We are currently using v7.0 build 3000. Thanks for the info... The show ends in May and not my machine; and not a huge problem. Glad to hear it's addressed in v8.5.
