Question 1
I have a lower third with a quad that have a video as material. The video have an input, a loop and an output sequence. I want the scene to begin with the input sequence played once, the loop sequence played in loop and paused indefinitely (with an event set in animation controller waiting for keyboard) and the output sequence played once.
How can I setup this? I separated the input and the loop sequences (input set with Play Once & Auto Start, and loop set with Loop & Auto Start), but how can I have in the loop sequence an indefinitely pause and start the output sequence synchronized with the loop?
Question 2
The Run Mode set to Free Running. The help file say "for this check box, use default setting". What default setting?
Question 3
The Run Mode set to Stopped. The help say "display the first frame in the video file, but do not play the video file". For what can be used? Is this helping for the situation described in the first question? Do I need a script to play the stopped video?
Thanks for the answers.
