  • 1.  GPI Trigger based on Datalinq Key
    Posted 10-03-2019 21:22
    I want to add a script to my scene director that will trigger a GPI # based on the datalinq key value. I could also do a text value I supposed that is datalinq'd. Any thoughts? Here is my intial go at it.
    dim key as xpDatalinqKey
    dim keys as xpDatalinqKeys
    dim txt as string
    scene.GetDatalinqKeys(keys)
    keys.GetKeyByName("JerseyNo", key)
    key.asString=txt
    engine.RefreshDatalinqs()
    dim rosstalk as xpGPIBoard
    Engine.GetGPIBoard(0, rosstalk)
    rosstalk.SendMessage("GPI + txt")
  • 2.  RE: GPI Trigger based on Datalinq Key
    Posted 11-06-2019 17:36
    I think that script will work - does it not?
  • 3.  RE: GPI Trigger based on Datalinq Key
    Posted 11-06-2019 17:44
    Where does txt get defined?
    currently you are saying key.asString = txt where txt is a string object;
    what you might want to try is changing the bottom line to the below if txt is suppose to be a string variable
    rosstalk.SendMessage("GPI "+ txt)
  • 4.  RE: GPI Trigger based on Datalinq Key
    Posted 11-06-2019 17:50
    Sorry,
    I missed the dim txt as string...
    the above changes recommended should work for what you need!
