  • 1.  Tagboard twitter scroll in XPression
    Posted 02-03-2019 02:39
    Currently, I don't have the powerful Inception, but am utilizing Tagboard. I am looking to have a bottom section scroll of tweets that's being generated from Tagboard and wanted to know if anyone has every used this and could lead me in the right direction to make this happen using Tagboard and XPression?
    Any leads would be helpful!
  • 2.  RE: Tagboard twitter scroll in XPression
    Posted 02-03-2019 02:57
    ** I am now seeing XPression Connect. Is there another option other than XPN Connect?
  • 3.  RE: Tagboard twitter scroll in XPression
    Posted 02-05-2019 18:26
    I would probably not recommend using XPression Connect for this.
    Tagboard is supported using the Datalinq RSS data source in XPression version 8.0 and above. Tagboard's v1.0 API can be set to RSS and is formatted in way XPression can read, including downloading of http images (avatars, attachments, etc).
    You can reach out to Tagboard for help setting up their RSS output.
  • 4.  RE: Tagboard twitter scroll in XPression
    Posted 02-03-2023 19:14
    All - Last post on this is from 2019.  We are attempting to use Tagboard as well.  Any new info that can be added would be greatly appreciated.
    ASB
    Graphics Designer II
  • 5.  RE: Tagboard twitter scroll in XPression
    Posted 02-06-2023 15:39
    There is no change to Tagboard support in XPression.
    Tagboard data is supported using the XPression Datalinq RSS Data Source.
  • 6.  RE: Tagboard twitter scroll in XPression
    Posted 02-07-2023 13:27
    Thanks - may need to contact Tagboard..... not seeing data from their link
    ASB
