Hi Ben,
With your animation sitting static between the in transition and the out transition, why don't you try this. Open the Scene Director for your scene. Drag the animation from the Media Manager, onto a track in your Scene Director, then add a "Pause" event to the frame where your animation's IN transition ends. If you don't need the animation to continue to play out, then the pause will see your animation hold until you hit the TAKE key on your keyboard again. If the number of frames between your IN transition and the OUT transition of your animation isn't too long, then the rest of the animation will play out and take your scene offline. If you do have a longer animation, as in my picture below, then you may want to add an "Event" to your scene director to have the play-head of the Scene Director's timeline jump to the frame just before your OUT transition starts. If you need assistance setting that up, let me know. If you want to share your project, I can set this up in your Scene Director as well.
