Hello all. We used to run tweets through Inception and Xpression on one of our shows. Since then we halted running the Tweets and also upgraded to Xpression 9.0 (don't know if that has anything to do with this or not). We are looking to run Tweets the way we used to, but when I linked everything up the way we had it before, it doesn't work (or I am missing a step).
I set up the template for the Tweet body of text to be hooked up to data (RSS Feed). In the Sequencer, I can manually go into the data source and change the Tweets, but can't set it up so we can add them to our playlist so it will populate automatically. I have also read other answers given on this subject but still can't get it to work.
Here is my data:
and here is my Scene info
Can anyone see what I am doing wrong? Any help is appreciated. Thank you.
