Hey Richie,
The answer is yes!
I'm assuming you are doing your template creation offline on a Designer system, if not the principle will remain the same.
On your designer system configure as many virtual framebuffers as your facility has physical outputs. In other words, If you have four channels on air you must simulate this on your designer with 4 virtual outputs. This can be done in the Edit > Hardware Setup menu.
Once you have done this you will find that within the scene object you will have four options instead of two for default framebuffer when creating a scene.
Cheers!
