  • 1.  Roll with Background
    Posted 09-11-2019 13:05
    Hi
    I'm trying to do a credit Roll like this one explain in this very good tutorial
    (https://www.youtube.com/watch?v=M1F64X23PHE)
    except that I wanted this to happen on a background  that would arrive just before the beginning of the credit roll and will disappear at the same time than the logo at the end.
    I can't figure out how to do that
    Can anybody help me?
    I work on Xpression v8
    Thanks , Michel
  • 2.  RE: Roll with Background
    Posted 09-12-2019 09:34
    Hi!
    Roll and crawl are very poor in Xpression.
    Try to do it manually using a long text object and animate it in Scene Manager.
    Put an Event object linked to the text and take an action when the event is visible.
    In my example I linked it to the text object using a space between them in Visible logic.
    Use a quad as a background.
    Link: https://www.dropbox.com/s/52mgs3omwwo3w3v/Credit%20Roll.xpf?dl=0
    Have FUN!
    Gabriel
  • 3.  RE: Roll with Background
    Posted 09-12-2019 18:52
    Thanks Gabriel for your help
    That's a good way to do it but as I want to see the different lines of text I manage to do something in creating a group shortcut where I play my page with the backround first , then the Group with the roll! It does the job.
    The only thing is when the roll is finished I don't know how to put the background offline
    I'm still working on it.
    Best Regards
  • 4.  RE: Roll with Background
    Posted 09-13-2019 19:32
    OK,
    You can create your own ROLL/CRAWL type group, but the first take item in ROLL group should recall a specific take item number (in order to show the background) and the last one other take item number (to take background offline) using a script.
    dim takeitem as xpBaseTakeItem
    engine.sequencer.GetTakeItemByID(101, takeitem)
    takeitem.Execute
    In my example the first roll item recall take item no 101 (Background ON) and the last/second one recall 102 (clear the background Layer and take it offline).
    The script is launched when the event is "visible".
    Link: https://www.dropbox.com/s/w44lc26zd3hln84/Credit%20Roll%20%2B.xpf?dl=0
    Have FUN!
    Gabriel
  • 5.  RE: Roll with Background
    Posted 09-16-2019 12:29
    Thanks Gabriel
    That's exactly what I needed
    Best Regards
    Michel
