Okay I've figured out from some videos that I can do a sercah within the drive elements of the attributes. So each drive has a sequence attribute so I could setup in the data links Drive do get the 7th drive. Is there any formula that could be input to just get the max number found in the array of elements?
I've tried Drive , Drive , Drive ect to no avail
