Per Object Masking
  • 1.  Per Object Masking
    Posted 10-29-2012 20:47
    I was told that one of the new features of Xpression 4 is per object masking. However I can seem to figure out how that is done. Does anyone know how this is done?
    Richie
  • 2.  RE: Per Object Masking
    Posted 10-31-2012 09:18
    Put a layer object (it act like a group), in it the object to mask and the mask (below). And tadam !
  • 3.  RE: Per Object Masking
    Posted 11-01-2012 20:53
    Not sure that I understand that. I tried creating a group and placed a quad with with a mask material in the group with the object I want to mask. Also tried the object to be masked and mask in various sibling and child/parent relationship. However I could not get anything to work. What am I missing?
  • 4.  RE: Per Object Masking
    Posted 11-02-2012 12:35
    A layer object, not a group... What is your version of Xpression ?
  • 5.  RE: Per Object Masking
    Posted 11-02-2012 17:42
    V4 Build 2025
  • 6.  RE: Per Object Masking
    Posted 11-02-2012 17:51
    Oh! Got it now. I thought all objects in the object manager were called layer objects. Very helpful, thank you!
    Richie
  • 7.  RE: Per Object Masking
    Posted 11-02-2012 18:15
    nice !
  • 8.  RE: Per Object Masking
    Posted 07-10-2013 15:21
    Figured out that XPression mask, is truly a mask, and not an alpha channel. Coming from other systems, that is confusing but true to the definition. However, if I put a Layer Object with two objects (the bottom one as the mask for the top one...) into a GROUP; the entire Layer Object vanishes. Is this a "feature" I don't know how to work? Or is this a bug that needs attention?
    XPression Designer Version 5.0 build 2312
  • 9.  RE: Per Object Masking
    Posted 07-17-2013 13:10
    This appears to be broken in Version 5.
    I tried upgrading to 5 and I scene I had already built previously in ver. 4 doesn't work anymore.
  • 10.  RE: Per Object Masking
    Posted 07-17-2013 13:11
    By which I mean I now have the same problem as Patrick where the whole layer disappears.
  • 11.  RE: Per Object Masking
    Posted 07-17-2013 13:20
    Try to change the render mode, I know that developpers fix a bug. Maybe this change is the problem you have.
  • 12.  RE: Per Object Masking
    Posted 07-18-2013 03:59
    I'm not sure what you mean by changing the "render mode."
    I did, however, make a mistake in my description of what happens in ver. 5. If I have a mask in a Layer Object with text (so there's a Layer Object with a text layer, and the mask is the child of the text layer), the mask does nothing. The text is always visible in the scene.
    In my case, I have a scene that starts "empty," and a background animation animates on. Then text layer animates from off screen to on screen, and another text layer is in the Layer Object, and the mask is supposed to move up to reveal the text. In ver. 5, however, the text layer is always visible.
  • 13.  RE: Per Object Masking
    Posted 07-27-2015 13:18
    Any tutorial on this subject would be greatly appreciated. I know there are 3 ways of dealing with transparency but I don't understand any of them. My teacher thought you need images with alpha but that is not true. Black and white PNG will do.
