  • 1.  Transition Logic exclude Layer
    Posted 04-01-2020 08:50
    Hi there.
    I want to create a transition logic with the following condition:
    check if any scene on any layer is online but ignore whats happening on layer 10
    or just check if a scene in layer range from 11 to 100 is online.
    I guess I need scripting for this, right?
    best regards
    Bernhard
  • 2.  RE: Transition Logic exclude Layer
    Posted 04-14-2020 22:23
    Hi Bernard,
    I don't quite understand what you're trying to do, but checking if something is on layer 10 can be done by adding a condition > CHECK SCENE/LAYER > select the layer and select INVERT.
    But then I don't know what you want to do with that.
    Could you explain more?
  • 3.  RE: Transition Logic exclude Layer
    Posted 04-15-2020 06:35
    I have a watermark that changes the color if any other element goes online. This works so far with transition logic check scene/layer any layer.
    BUT: I have one scene on layer 10 (with different take IDs) that should NOT change the color of the watermark. So i need an exception for my transition logic.
