  • 1.  Input grabber file type
    Posted 07-27-2020 10:32
    Is it possible to change the file type when using the Input Grabber? I would like to change the "TGA" to "JPG" because I don't need the alpha channel when grabbing...
  • 2.  RE: Input grabber file type
    Posted 07-27-2020 11:55
    Rob,  if you use the "grabber" in the record client instead, it has the ability to grab stills as PNG.  Sorry JPG is not currently support.
  • 3.  RE: Input grabber file type
    Posted 07-27-2020 12:03
    Thanks for the quick response! Could this be a feature request?
  • 4.  RE: Input grabber file type
    Posted 07-27-2020 12:07
    Hi Rob, we could look at adding this to 10.1.
