  • 1.  Multiple Scene Groups in Group take inspector
    Posted 01-20-2021 20:37
    I have a group of crawls  that I am working on that I am trying to automate with the Take inspector. I can get them to loop through by themselves but when I try to add more than one in the take inspector it doesn't loop through them. How would I go about doing this?
  • 2.  RE: Multiple Scene Groups in Group take inspector
    Posted 01-20-2021 21:34
    Added a event marker with the following script added to event. This seems to be a work around and does give me the desired output. If there is a easier or more preferred method I am open to ideas.
    dim takeitem as xpBaseTakeItem
    engine.sequencer.GetTakeItemByID(1001, takeitem)
    takeitem.execute
  • 3.  RE: Multiple Scene Groups in Group take inspector
    Posted 01-25-2021 19:01
    I had a similar problem with 61 back to back rolls. It should be similar to crawls if you know their duration.
    Try playing with the Scene Director and setting the end to the duration of your Crawl. We figured out the duration in the Object Inspector - scene group tab and changing the duration from Speed to Frames, noting the frames and then changing back to speed.
