I get this error when using the xpengine object in an excel macrol on Windows 10. Works fine on Windows 7.
Jonas,
You need to run excel as admin.
Running as local admin.
Can you check in task manager under "Details" with the Elevated column what Excel shows?
Elevated = No
UAC Virtualization = Disabled
Okay, that means Excel is not running as admin; can you try right clicking and run as admin?
Thank you! That fixed it.
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
