  • 1.  Setting a Default Docking Layout?
    Posted 09-29-2020 15:52
    Is there any way of changing which docking layout loads when XPression Studio v9 is launched?  (Or, failing that, any way of overwriting the built-in <default> layout?)  Thanks!
  • 2.  RE: Setting a Default Docking Layout?
    Posted 09-29-2020 16:04
    Hello Ben
    I haven't found a way to default it to my saved layout, which is a pain.  However when you have XPression Open in either the Sequence or Layout view, you choose and move all your boxes around to they way you like it and then right beside the Dropdown where it says default, if you click that icon it will prompt you to save your layout.  Choose your name and hit enter.
    Repeat the process for the other area ie Sequence.
    Hope that helps.
  • 3.  RE: Setting a Default Docking Layout?
    Posted 09-29-2020 16:54
    Hey all,
    XPression will remember the last used docking layout as long as there is a sequencer and layout editor layouts are  saved with the same name.
    To make this work:
    1. Make a layout you want to use in Sequencer and save it
    2. Make a layout in layout editor and save it with the same name as the sequencer
    Once both Layout editor and Sequencer have layouts with the same name XPression will recall it on start up.
    This has been improved and will be in future releases.
  • 4.  RE: Setting a Default Docking Layout?
    Posted 09-29-2020 16:58
    That works perfectly for me--thanks much!
