  • 1.  Take Item naming using Xpression Prime
    Posted 09-24-2020 21:32
    Hello i was wondering if there is an easy way to have the take items named from a datalinq? I am creating about 2000 take iems for a graduation ceremony. and at the end i am wanting to export the take items but is there a way to name the take items using a datalinq text field?
  • 2.  RE: Take Item naming using Xpression Prime
    Posted 03-24-2021 18:38
    You can create the take items via XML which you can load or there's even a watch folder option.
