Quad objects:
Logo
Bar
Text objects:
Day: manually entered
Date: Clock Timer widget format MM/DD
DayDateDisplay: fed in Visual Logic
Make Logo child of Group1
Make DayDateDisplay child of Logo
Unlock position of Group1 in Pivot (red circle)
I manually set position of logo to center composite after building visual logic.
Note: If you could find a clock timer format that would give you the name of the day as well, use Left String to trim off Month/Date
