  • 1.  Crawl with Datalinq where the number of rows/scenes vary
    Posted 02-03-2021 22:56
    I have created a crawl. It contains 10 text scenes within a scene group (set to crawl) each Data linked to their designated cells in Excel. The final cell has web links which will always end the crawl. However, if we are only required to use 5 cells at one time, how do I script my scene to remove the remaining (blank) 4 scenes and jump to show scene 10 (with website links) without any extra spacing being added to the crawl?
  • 2.  RE: Crawl with Datalinq where the number of rows/scenes vary
    Posted 03-19-2021 12:24
    So have you currently built 10 entire scenes for each text cell?
    Do you know that you only need to build perhaps 3-5 and then use the n+ method to read the rest until you final scene?
    Let me know if not and I can help you with that.
