  • 1.  Xpression Radar/Spider/Web Chart
    Posted 01-21-2021 09:01
    Hi everyone,
    Just wondering, if anyone has tried making a radar/spider/web chart in XPression?
    is it even posible to make it in XPression?
  • 2.  RE: Xpression Radar/Spider/Web Chart
    Posted 01-21-2021 15:07
    Short answer yes, if you like scripting and trigonometry (maybe even a little calculus) you can achieve something with the xpAPITextureShader.
    Long answer: Below is a very experimental script that is attempting to accomplish that. If I'm being honest it's been so long since I did this I can't remember where my head was at when I was doing it. It's lacking any/all functionality beyond just drawing a hardcoded pentagon to a specific set of coordinates. By the time I got to this point we no longer had a need to explore this so I abandoned it where it is now.
    From where I left off, the next steps (and probably the hardest) would be:
    • Convert user inputted datasets to work within your constraints so they would fit within your bounds
    • Draw a line from your polygon's origin point (which isn't 0,0 because Xpression scene's 0,0 is in the lower left so it has to be offset)
    • Take the x,y of those end points and storing them into an array (pointslist)
    • Connecting those points with the DrawPolygon and FillPolygon functions
    And then there's probably stuff I'm missing, again it's been awhile.
    Engine.DebugMessage("Start",0)
    ' Material Declarations
    dim Mat as xpMaterial
    dim APITexture as xpAPITextureShader
    dim Pen as xpPen
    Engine.GetMaterialByName("PentMat", Mat)
    Mat.GetShaderByName("APIPent", APITexture)
    APITexture.Clear
    Pen = Engine.CreatePen
    Pen.Size = 5
    Pen.SetColor(0, 0, 255, 255)
    ' Coordinate Centering / Guide Ellipse Drawing
    dim CircleSize as Integer = 500
    dim CircleRad as Integer = CircleSize/2
    dim CirclePosX as Integer = 960 - CircleRad
    dim CirclePosY as Integer = 540 - CircleRad
    APITexture.DrawEllipse(Pen,CirclePosX,CirclePosY,CircleSize,CircleSize)
    APITexture.DrawEllipse(Pen,960-CircleRad/2,540-CircleRad/2,CircleRad,CircleRad)
    ' Pentagon Centering and Drawing
    Pen.SetColor(255,125,0,255)
    APITexture.DrawLine(Pen,960,540,960,540+CircleRad)
    APITexture.DrawLine(Pen,960,540,1200,610)
    APITexture.DrawLine(Pen,960,540,1125,353)
    APITexture.DrawLine(Pen,960,540,795,353)
    APITexture.DrawLine(Pen,960,540,720,610)
    dim PentCoords as xpPointList
    PentCoords = Engine.CreatePointList
    dim Con as Double = 180/Math.Pi
    dim FillBrush as xpBaseBrush
    Engine.CreateBrush(0,FillBrush)
    FillBrush.SetColor(250,150,150,135)
    Pen.SetColor(255,150,150,255)
    ' HardCoded Points
    PentCoords.AddPoint(960,540+CircleSize/2) 'p1
    PentCoords.AddPoint(1200,610) 'p2
    PentCoords.AddPoint(1125,353) 'p3
    PentCoords.AddPoint(795,353) 'p4
    PentCoords.AddPoint(720,610) 'p5
    ' Procedural Points
    APITexture.DrawPolygon(Pen,PentCoords)
    APITexture.FillPolygon(FillBrush,PentCoords)
    Engine.DebugMessage("Convert = " & Math.Cos(18),0)
    Engine.DebugMessage("Cosine Result Needs to Equal ~1200 = " & 960 + CircleRad*(Math.Cos(18)/Con),0)
    Engine.DebugMessage("Sine = " & 540+(250*Math.Abs(Math.Sin(18))),0)
    Engine.DebugMessage("Complete",0)
  • 3.  RE: Xpression Radar/Spider/Web Chart
    Posted 01-22-2021 07:19
    Wow! Thanks Martin Goetz, I'll try it out!
