  • 1.  Overdrive, Xpression, Dissolve
    Posted 10-23-2020 23:07
    To whom it may concern...
    When trying to dissolve from one Full Page graphic to a second Full Page graphic,
    even when using the Dissolve button it always Cuts to the next Full Page.
    Has anyone experienced this before?
    Is it something in the template of the full page?
    How do I fix this issue?
    Mark.
  • 2.  RE: Overdrive, Xpression, Dissolve
    Posted 11-13-2020 08:45
    In the XPression CII Gateway (software on the Studio/BlueBox) there is a setting called  "repeated page reads" - that needs to be set to "continue" - it is probably set to "restart" right now.
