  • 1.  Perspective Camera Moving When Not Selected
    Posted 01-20-2021 10:44
    I have had an issue recently when editing in XPression regarding perspective cameras moving when I slide my fingers on the touchpad of my laptop. This move happens when I have my pointer over another area of the window (materials or layers) and *do not* have the camera selected.
    For example, I will want to scroll down on the materials window, so I will slide my fingers, and the view in the window will change as the perspective camera is moved when I slide my fingers. This move is often to an extreme distance (like 100,000+).
    Because "undo" essentially is useless in XPression, I am then required to exit out of the project w/o saving & reopen it to get the camera back to the right spot.
    This happens randomly & is very aggravating. Is there any solution to this, or should I just never edit w/ a touchpad?
  • 2.  RE: Perspective Camera Moving When Not Selected
    Posted 01-21-2021 17:05
    I don't know about trackpads---I avoid them like the plague, but if you keyframe the position of your perspective camera, you could bump the scene director to get it back where it should be.
  • 3.  RE: Perspective Camera Moving When Not Selected
    Posted 01-22-2021 15:23
    You can then put that animation on a key bind if you wanted effectively creating a home for your camera.
    Undo does work on items in the transform tab so undo should move the camera back to it's previous position.
    I use a trackpad a lot and have not seen this issue, I am trying to recreate it, what version are you on?
