  • 1.  Save vs Save All
    Posted 02-28-2021 20:35
    Hey!  What is the difference between Save and Save All?
    Im sure this a pretty rudimentary answer, but I cant seem to find the exact wording on the community, on the youtube page, or in the notes.
    We have had a few issues where our xpression has rebooted and when we log in, our scenes are not associated with the sequencer items. We used the Save button, but didnt use the Save All button before the comp shut down.  Are there additional items that save when you select Save All?
    Thanks in advance!
  • 2.  RE: Save vs Save All
    Posted 03-12-2021 20:25
    Save All will save all your projects you have open.  If you only have one project open there is no difference.
    If you have multiple projects open and are using a "projectgroup" then you would need to make sure to use Save All to make sure all the sequencer items are saved too.  The sequencer items get saved in the "projectgroup" file because the sequence may contain items from different projects and so they need to be saved in the group so that the order of them is retained relative to items from other projects.
