I use Visual Logic to scale boxes according to the width of text. When I have the autosqueeze on a text field, the box continues to expand once the squeeze begins. Is there a way to set the maximum width of how much a box scales on the X axis, preventing the box to keep scaling?
I have used masks and other ways to get around this before, but I have a situation where I'm using an odd shaped box where a mask would be more difficult to create. I've also tried different ways using the "Max Value" block with the "Value" and Input Selectors, but never got it to work. It seems to me there is a way to do this that I can't figure out.
I would greatly appreciate any help on this. Thank you.
