You should probably use playrange.
this would jump to 200 and play until 300
if checktext.text = "STOP" then
dir.playrange(200, 300)
end if
or you can replaced the fixed number with duration of the scene director so...
dir.playrange(200, dir.duration)
end if
of course you'll need to go get the scene and scenedirector from the engine before that will work. You ok with that bit?
