  • 1.  QUERY FOR PLAYING A SCENE DIRECTOR THRU VISUAL LOGIC
    Posted 09-21-2020 13:27
    Hi guyz,
    My query is in regards to VL. I have a series of data in excel for an esports tournament. 1 of the graphic shows the score of all the team during live game. This graphic needs to be dynamic with team name and score being shown in descending order based on the score.
    I want to arrange data in descending order in XPN using excel database. I can do that by putting an SQL query in the Set Datalinq Properties of DataSource. So having data on XPN in descending order according to score is not a problem.
    But i want to animate individual groups which contains the cube and text of each team when ever their position on the scoreboard changes according to the score. I.e when team2 score is higher then team1 then an animation should play which replaces their position. This animation should happen only to the Teams whose position changes in the scoreboard.
    My XPN scene structure with multiple groups of each team is
    TEAM1 (group)
      ->Teamname1
      ->Score1
      ->Cube
    Each team group has a rotational animation in individual scene directors.
    How can i use VL to play the scene director when a teams position changes in the scoreboard?
    Hope i am able to explain what i need to achieve. Please let me know otherwise.
    Gaurav
  • 2.  RE: QUERY FOR PLAYING A SCENE DIRECTOR THRU VISUAL LOGIC
    Posted 03-24-2021 18:39
    Hey Gaurav, hope you're well, did you get your answer for this?
  • 3.  RE: QUERY FOR PLAYING A SCENE DIRECTOR THRU VISUAL LOGIC
    Posted 03-25-2021 06:05
    Hi RED,
    Haven't been able to figure out how to do this.
    Gaurav
    #XPression​​​
  • 4.  RE: QUERY FOR PLAYING A SCENE DIRECTOR THRU VISUAL LOGIC
    Posted 03-25-2021 10:49
    Hey Gaurav, so if I understand you want the position to change but not just snap position you want them to animate?
