  • 1.  Play Scene Director through a Script
    Posted 11-11-2020 11:14
    I'm trying to add a script on the Keyboard Mapping to be able to trigger a Scene Director so I can "activate" that Scene Director with a keyboard shortcut.
    Is there a simple script that will trigger a Scene Director in my Message?
    Thank you!
  • 2.  RE: Play Scene Director through a Script
    Posted 11-11-2020 14:59
    Hey Paulo-
    In the "Keyboard/GPI Mapping" area, you should be able to drag a "Script Action" into the Project Shortcuts.  Then, you'll edit the script action (Sub OnKeyPress) to do something like this...
    Option 1, if you always want to play a scene director from a particular scene:
    dim Scene as xpScene
    dim sd as xpSceneDirector
    Engine.GetSceneByName("ExampleScene", Scene, false)
    Scene.GetSceneDirectorByName("ExampleSceneDirector", sd)
    sd.play
    Option 2, if you want to play a particular scene director for whatever scene is on framebuffer 1, layer 1:
    dim output as xpOutputFrameBuffer
    dim onlineScene as xpScene
    engine.Getoutputframebuffer(0, output)
    output.GetSceneonlayer(1, onlineScene)
    onlineScene.GetSceneDirectorByName("ExampleSceneDirector", sd)
    sd.Play
    Once you get a script working, you can assign a keyboard shortcut to this GPI/Script Action.  Let me know if you have issues!
    Bo
  • 3.  RE: Play Scene Director through a Script
    Posted 11-23-2020 06:41
    Thanks a lot Bo!
    I was able to get the second script right, the one that plays anything that is on the Frame Buffer. It was very useful on the show.
    But I couldn't get the first one to work, I've tried a few different variations and nothing.
    Any idea of what could have happened? Did you get the same script to work on your machine?
  • 4.  RE: Play Scene Director through a Script
    Posted 01-13-2021 14:10
    Hey,
    I think the problem with the first one is that you need to put the scene on-air as well. Try this.
    Dim Scene as xpScene
    Engine.GetSceneByName("YOUR SCENE NAME", Scene,False)
    Scene.SetOnline(1,0,0)
    Scene.GetSceneDirectorByName("SceneDirector1", sd)
    sd.play()
