    Posted 03-12-2021 18:26
    Hello all, I was just curious about something.  Whenever I apply a  .jpg  image to my template from the sequencer it appears correctly.  When I apply a  .jpeg  image the same way it's always rotated 90 degrees.  Has anyone else encountered this?
  • 2.  RE: .jpg vs .jpeg
    Posted 03-12-2021 20:23
    Try renaming your good ".jpg" to ".jpeg" and try that to confirm..  My "guess" is that whatever is generating your "jpeg" files is using some internal EXIF data to mark it as rotated and XPression does not support that tag to "unrotate" it.  You'll see this with cellphones sometimes; they record the picture sideways and set a flag in the EXIF data to indicate it is rotated 90 degrees but not all image viewers support this to "unrotate" it (including XPression).
  • 3.  RE: .jpg vs .jpeg
    Posted 03-12-2021 20:32
    Thanks Brian. I was guessing it was something like that...
