  • 1.  XPression GPO
    Posted 02-09-2021 21:37
    Wanting to have XPression send GPO to a JL Cooper box on scene launch. Is this possible? Is there documentation? Examples: on scene launch latch pins 2 & 4 to ground; on scene launch latch pin 2 only; on scene launch latch pins 2 & 3 to ground; etc.
  • 2.  RE: XPression GPO
    Posted 03-19-2021 12:06
    You want to something along the lines of this?
    'The “0” in the GetGPIBoard is the index of the GPI board in Hardware Setup > GPI Boards
    '(Board #1 = Index 0, Board #2 = Index 1, etc..)
    Physical GPO:
    OnOnline:
    Dim gpi As xpGPIBoard
    If engine.GPIBoardCount > 0 Then
        engine.GetGPIBoard(0, gpi)
        gpi.SetOutputPinState(0, true)
    End If
    OnOffline:
        gpi.SetOutputPinState(0, false)
    End If
